Customer jetting for a KX500
Post by Sandblaster » Mon Jun 26, 2017 3:17 pm
Balanced, mild port, stock compression, Fatty desert pipe, Rad valve
4500ft
92 octane clear gas
52 pilot
170 main
NEEDLE-JET,N89D | 16009-1613 needle at the top position
All Stock engine, stock pipe, stock pipe
Sea level
110 fuel
160 main and a 50 pilot, stock needle
Same bike Running the quad vent airstriker, 162 main and a 45 pilot. 110 octane fuel. I think I could drop to a 42 pilot.
I can get it to idle with the air screw out 2.5 turns.
moto939
Re: Customer jetting for a KX500
Post by moto939 » Wed Jul 05, 2017 6:29 pm
Glad you made this post so I could confirm what I'm finding....
2001 stock motor
Rad Valve and reed spacer
RM250 short body air striker with Boyesen power wing
1200-1500 ft
110 vp/93 premium-no ethanol
50:1 K2 Maxima
stock needle #2 clip #7 slide
160 main
started with a 52 pilot but could tell in the driveway way too rich, so went to a 45. But like you, needed to be 2.5 ish out on the air screw to get a decent idle. Ran ok, but could tell it was loading up and studdering at low speed. Was running low on time, but dropped in a #8 slide and took it for a quick spin. Big difference.....definitely ran cleaner and smoothed out that transition from low to mid. It ran like a different bike. :D I'm still going to drop to a 42 to get the air screw back into 1.5 or so. If you have any spare #7 slides laying around, it might be worth cutting one to a 8 just for a tuning option.
This carb has such a strong vacuum signal (not sure if that's the correct term or not) that I'm starting to wonder if the stock needle is the way to go. I may measure some of the needles I have and see if any are worth a try.
Post by Sandblaster » Wed Jul 05, 2017 8:20 pm
As soon as I get to mine I will record my findings.
Everything I have seen says that the short bodied air strikers when correctly tuned and jetted will give way better throttle response....
Post by Sandblaster » Tue May 08, 2018 8:18 pm
Leo Sadzewicz
So...
I’ve been doing a whole lot of jetting experiments, bought every needle, every jet, and every slide.
And I have successfully gotten rid of all lean surging.
I’m at 3825’
#55 pilot
N82M 4th(stock)
182 main
#9 slide (which actually cures the problem for higher elevations)
Perfect usable power from idle to the moon.
I know there’s gonna be naysayers, let the crap begin :lol:
Post by Sandblaster » Sun May 27, 2018 9:38 pm
Coby Hosford
5000’ running a N82L 3rd clip 62 pilot 168 main gets rid of that deceleration surge and replaces it with a tractor like acceleration smooth all the way to the top.
