Bottom end identification
Bottom end tips and mods
borntworide
Post by borntworide » Sun Feb 07, 2021 5:26 pm
I am looking at used bottom end for my 97 kx 250 , its on eBay is there any way to tell what year without the side cover with vin?
Re: Bottom end identification
Post by Sandblaster » Mon Feb 08, 2021 4:32 am
Cylinder ID and carb ID
borntworide
Post by borntworide » Fri Feb 12, 2021 4:07 pm
It's just a lower end ,no cylinder , head or side cover! That's why i was wondering if there was a way to determine what year it was from actually.
Post by Sandblaster » Fri Feb 12, 2021 7:02 pm
It can be narrowed down to a year range.
97-04 USE A LARGER SHIFT FORK PIN & 1 LESS CASE BOLT & NARROWER SHIFT DRUM
Is the engine apart?
borntworide
Post by borntworide » Fri Feb 12, 2021 7:11 pm
No the cases are not separated yet. Where is the case bolt missing from?
borntworide
Post by borntworide » Wed Feb 24, 2021 5:38 pm
Finally got the lower half after all that the engine is on it. For some reason I had it stuck in my head engine number was on the side cover not the case.
KX250KE017363
Post by Sandblaster » Thu Feb 25, 2021 4:30 am
95-98
If you had the cylinder or carb we could nail the year.
SHIFT FORK ROD GUIDE SHAFTS 1995 9.98MM OD
SHIFT FORK ROD GUIDE SHAFTS 1996-1998 11.89MM OD
borntworide
Post by borntworide » Wed Mar 10, 2021 12:38 pm
I see what you mean with the extra bolt, my case and cover do not match. From what you stated the lower end is 97 up and the cover is 96 down? Is that correct or do I have it backward? The bolt in the red circle goes all the way through the right side cover to the case, the red arrow is the extra bolt hole.
Posting pic for clarification
kx case.JPG (153.68 KiB) Viewed 228 times
Post by Sandblaster » Thu Mar 11, 2021 3:42 am
I don't know, I'm a 500 guy :lol:
borntworide
Post by borntworide » Thu Mar 11, 2021 11:54 am
:lol:
Return to “Bottom end”
