Post by Sandblaster » Fri Nov 17, 2017 12:32 am
Before I go any farther... I'm going to test this filler for expansion due to heat...
I hope it holds up well but that's why you experiment.. :shock:
KX GURU RACING TSR BUILT BILLET KX500 ENGINE CASE with a 2 piece clutch cover 133.jpg
KX GURU RACING TSR BUILT BILLET KX500 ENGINE CASE with a 2 piece clutch cover 133.jpg (241.5 KiB) Viewed 6870 times
Post by Sandblaster » Sun Nov 19, 2017 8:29 pm
This pipe was designed for more mid to top end out of. Also, this specific pipe is for running a electric starter in a Aluminum chassis or KTM conversion... If interested, let me know and I will give you some guys to talk to.
Yes, this will be going on my KTX500E build :lol:
KX GURU RACING 2016 KTM 250SXF KX500 CONVERSION PIPE 170.jpg (280.66 KiB) Viewed 6862 times
Post by Sandblaster » Wed Nov 22, 2017 3:31 pm
Here is the template for the electric starter after Mathew modded it a bit more.. 8-)
KX GURU RACING 2016 KTM 250SXF KX500 CONVERSION PIPE 171.jpg (68.28 KiB) Viewed 6851 times
Post by Sandblaster » Wed Nov 29, 2017 7:43 pm
Ok... the fillers did not work.
Every time I got the temps up much past 250f the putty would crack.
So, enough playing with the putties and fillers..
I took the cover to the welder and had him fill it in :o
KX GURU RACING TSR BUILT BILLET KX500 ENGINE CASE with a 2 piece clutch cover 129.jpg
KX GURU RACING TSR BUILT BILLET KX500 ENGINE CASE with a 2 piece clutch cover 129.jpg (629.98 KiB) Viewed 6821 times
I have a little work to do just yet on it but making good progress...
Post by Sandblaster » Wed Nov 29, 2017 8:00 pm
I almost have this carb ready to go..
KX GURU RACING KTX500E BUILD CARB 127.jpg (364.98 KiB) Viewed 6820 times
Post by Sandblaster » Tue Dec 12, 2017 11:33 pm
The pipe is in but needs a bit of work yet..
talk to the pipe.jpg (486.57 KiB) Viewed 6776 times
Post by Sandblaster » Wed Dec 13, 2017 3:06 pm
KX GURU RACING 2016 KTM 250SXF KX500 CONVERSION PIPE 172.jpg (350.66 KiB) Viewed 6770 times
KX GURU RACING 2016 KTM 250SXF KX500 CONVERSION PIPE 173.jpg (358.9 KiB) Viewed 6770 times
KX GURU RACING 2016 KTM 250SXF KX500 CONVERSION PIPE 174.jpg (276.66 KiB) Viewed 6770 times
KX GURU RACING 2016 KTM 250SXF KX500 CONVERSION PIPE 175.jpg (375.16 KiB) Viewed 6770 times
KX GURU RACING 2016 KTM 250SXF KX500 CONVERSION PIPE 176.jpg (516.17 KiB) Viewed 6770 times
KX GURU RACING 2016 KTM 250SXF KX500 CONVERSION PIPE 177.jpg (429.69 KiB) Viewed 6770 times
Post by Sandblaster » Wed Dec 13, 2017 3:18 pm
One of the many issues you run into when building a conversion is lack of color availability.
I have been working hard on stripping off the pumpkin rind and replacing with the beautiful Kawasaki Green scheme..
When it came down to the seat, nobody made a Kawasaki color scheme for the KTM..
What to do?
Oscar from KX Guru Racing called his buddies at Guts Racing and they set me up!!!
https://www.gutsracing.com/
Ph: 800-342-1272
6165 Enterprise Dr
Diamond Springs
CA
Email: sales@gutsracing.com
Facebook: https://www.facebook.com/guts.racing/
Check this work of art out...
kx guru racing guts racing custom seat 101.jpg (497.84 KiB) Viewed 6766 times
kx guru racing guts racing custom seat 102.jpg (494.82 KiB) Viewed 6766 times
Not only did they nail the colors but they used a soft foam which is very important when you get older and realize that your no longer a iron man :lol:
Thanks Guts racing, I really, really, appreciate it!
Post by Sandblaster » Thu Dec 14, 2017 3:40 pm
I guess I should clean up the shop a bit before I post any pics... You can never tell where they may end up..
MXA INSTAGRAM.png (467.81 KiB) Viewed 6758 times
Post by Sandblaster » Thu Dec 14, 2017 3:53 pm
The pipe came with some mounting brackets for the pipe to the chassis..
I have to either figure out something for this mount or I have to move it :shock:
It would be nice to move the bracket back here..
Users browsing this forum: No registered users and 15 guests
