JT Engine Works 1989 RM250 engine build
Posted: Fri Aug 12, 2016 12:18 am
I'm a bit late in all of this...
So this is a quick recap.
Disassembled, Vapor blasted, lapped, and vapor blasted again engine cases.
All new bearings, seals, gaskets, o-rings, washers, bushings, snap rings, alignment pins, ect.
The crank is balanced, polished rod, trued, welded.
The cylinder is plated but left at stock bore with stock port timing.
It does have some scuff n buff to clean up the factory casting flaws..
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 101.JPG (181.99 KiB) Viewed 1868 times
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 102.JPG (163.21 KiB) Viewed 1868 times
Re: JT Engine Works 1989 RM250 engine build
Posted: Fri Aug 12, 2016 12:19 am
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 103.JPG (256.17 KiB) Viewed 1867 times
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 104.JPG (192.73 KiB) Viewed 1867 times
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 105.JPG (187.91 KiB) Viewed 1866 times
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 106.JPG (181.46 KiB) Viewed 1866 times
Posted: Fri Aug 12, 2016 12:20 am
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 107.JPG (193.08 KiB) Viewed 1865 times
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 108.JPG (170.7 KiB) Viewed 1865 times
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 109.JPG (177.19 KiB) Viewed 1865 times
Jason is so fussy it's crazy... But good crazy... More tomorrow...
Posted: Tue Aug 16, 2016 12:07 am
Jason made some more progress today..
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 110.JPG (132.57 KiB) Viewed 1860 times
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 111.JPG (164.67 KiB) Viewed 1860 times
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 112.JPG (152.55 KiB) Viewed 1860 times
It's really turning out nice...
Posted: Tue Aug 16, 2016 4:16 am
More progress tonight
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 113.JPG (196.93 KiB) Viewed 1856 times
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 114.JPG (246.17 KiB) Viewed 1856 times
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 115.JPG (236.07 KiB) Viewed 1856 times
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 116.JPG (165.22 KiB) Viewed 1855 times
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 117.JPG (169.81 KiB) Viewed 1855 times
Posted: Tue Aug 16, 2016 4:17 am
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 118.JPG (173.43 KiB) Viewed 1854 times
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 119.JPG (188.54 KiB) Viewed 1854 times
Should have it ready to ship tomorrow... :shock:
