KX GURU Racing kx500 Engine in a 2016 KTM 250 SX PUMPKIN SEEDS BUILD
Post by Sandblaster » Sat May 18, 2019 1:49 am
Special Thanks goes to Alex Ward from Crazy Al's racing for getting me this 8 cet Anti Gravity battery...
Let's get wiring this puppy up...
KX GURU RACING KTX500E 304.jpg (240.12 KiB) Viewed 849 times
Post by Sandblaster » Sun May 26, 2019 4:35 am
Jason Tanner came out today and we made some good progress.
KX GURU RACING KTX500E 301.jpg (289.8 KiB) Viewed 831 times
KX GURU RACING KTX500E 302.jpg (486.46 KiB) Viewed 831 times
KX GURU RACING KTX500E 303.jpg (436.95 KiB) Viewed 831 times
KX GURU RACING KTX500E 304.jpg (449.2 KiB) Viewed 831 times
KX GURU RACING KTX500E 305.jpg (450.35 KiB) Viewed 831 times
KX GURU RACING KTX500E 306.jpg (499.77 KiB) Viewed 831 times
KX GURU RACING KTX500E 307.jpg (413.25 KiB) Viewed 831 times
KX GURU RACING KTX500E 308.jpg (433.71 KiB) Viewed 831 times
Post by Sandblaster » Wed Jun 12, 2019 3:02 am
Started working on the rear brake lever...
Since the KX500 engine is way wider than the 250 SXF engine the rear brake lever needed tweaking.
I also tried a 450 SXF lever but even it fell short.
So I grabbed a piece of aluminum and starting hacking my lever up.
KTX500E KX GURU RACING 301.jpg (780.44 KiB) Viewed 773 times
KTX500E KX GURU RACING 302.jpg (560.7 KiB) Viewed 773 times
KTX500E KX GURU RACING 303.jpg (648.37 KiB) Viewed 773 times
Post by Sandblaster » Wed Jun 12, 2019 3:06 am
After weld and rough blending...
Keep in mind that it is rough...
KTX500E KX GURU RACING 304.jpg (972.09 KiB) Viewed 772 times
KTX500E KX GURU RACING 305.jpg (884.8 KiB) Viewed 772 times
KTX500E KX GURU RACING 306.jpg (940.38 KiB) Viewed 772 times
KTX500E KX GURU RACING 307.jpg (651.66 KiB) Viewed 772 times
KTX500E KX GURU RACING 308.jpg (592.28 KiB) Viewed 772 times
Post by Sandblaster » Wed Jun 12, 2019 3:07 am
Roughed in and ready for final blending, sanding, and Cerakote
KTX500E KX GURU RACING 309.jpg (676.3 KiB) Viewed 771 times
KTX500E KX GURU RACING 310.jpg (720.49 KiB) Viewed 771 times
Post by Sandblaster » Wed Jun 12, 2019 3:08 am
Kill switch came in :D
Post by Sandblaster » Wed Jun 12, 2019 3:15 am
I decided that the gas tank looked a little rough for this level of build.
Since Cerakote was designed for use on plastic I decided to give it a try.
Worst case scenario is I'll have to buy a new tank :shock:
KX GURU RACING CERAKOTE 101.jpg (120.19 KiB) Viewed 769 times
KX GURU RACING CERAKOTE 102.jpg (191 KiB) Viewed 769 times
KX GURU RACING CERAKOTE 103.jpg (214.6 KiB) Viewed 769 times
EPIC FAILURE!!!
Time to start over... :roll:
Post by Sandblaster » Wed Jun 12, 2019 3:19 am
On the bright side, the rear brake lever turned out GREAT!!!
KTX500E KX GURU RACING 311.jpg (135.82 KiB) Viewed 768 times
KTX500E KX GURU RACING 312.jpg (111.2 KiB) Viewed 768 times
KTX500E KX GURU RACING 313.jpg (235.21 KiB) Viewed 768 times
Post by Sandblaster » Tue Jun 25, 2019 5:19 pm
Posted this last night but had a technical glitch 😲 Some of you have been following this build.. KtX500e Fired it up last night for the first time... There is a bit of humor there.... Jason Tanner handled the situation like a Pro 😂
https://www.youtube.com/watch?v=P1Z_3ZOCtZ0
Post by Sandblaster » Fri Jun 28, 2019 6:25 pm
The muffler is now re-cored to match the KX500 ID..
It was a real job trying to find someone to weld Titanium for me.
My new friend Rob Jeffers did a great job.
He is now working on the pie pieces to go from the inlet of the muffler to the outlet of the expansion chamber...
Can't wait to hear it when it's done...
