Page 20 of 26
Posted: Sat May 18, 2019 1:49 am
Special Thanks goes to Alex Ward from Crazy Al's racing for getting me this 8 cet Anti Gravity battery...
Let's get wiring this puppy up...
- KX GURU RACING KTX500E 304.jpg (240.12 KiB) Viewed 7404 times
Posted: Sun May 26, 2019 4:35 am
Posted: Wed Jun 12, 2019 3:02 am
Started working on the rear brake lever...
Since the KX500 engine is way wider than the 250 SXF engine the rear brake lever needed tweaking.
I also tried a 450 SXF lever but even it fell short.
So I grabbed a piece of aluminum and starting hacking my lever up.
- KTX500E KX GURU RACING 301.jpg (780.44 KiB) Viewed 7328 times
- KTX500E KX GURU RACING 302.jpg (560.7 KiB) Viewed 7328 times
- KTX500E KX GURU RACING 303.jpg (648.37 KiB) Viewed 7328 times
Posted: Wed Jun 12, 2019 3:06 am
Posted: Wed Jun 12, 2019 3:07 am
Roughed in and ready for final blending, sanding, and Cerakote
- KTX500E KX GURU RACING 309.jpg (676.3 KiB) Viewed 7326 times
- KTX500E KX GURU RACING 310.jpg (720.49 KiB) Viewed 7326 times
Posted: Wed Jun 12, 2019 3:08 am
Kill switch came in
- 20190608_123718_resized.jpg (938.66 KiB) Viewed 7325 times
Posted: Wed Jun 12, 2019 3:15 am
I decided that the gas tank looked a little rough for this level of build.
Since Cerakote was designed for use on plastic I decided to give it a try.
Worst case scenario is I'll have to buy a new tank
- KX GURU RACING CERAKOTE 101.jpg (120.19 KiB) Viewed 7324 times
- KX GURU RACING CERAKOTE 102.jpg (191 KiB) Viewed 7324 times
- KX GURU RACING CERAKOTE 103.jpg (214.6 KiB) Viewed 7324 times
EPIC FAILURE!!!
Time to start over...
Posted: Wed Jun 12, 2019 3:19 am
Posted: Tue Jun 25, 2019 5:19 pm
Posted this last night but had a technical glitch
Some of you have been following this build.. KtX500e Fired it up last night for the first time... There is a bit of humor there.... Jason Tanner handled the situation like a Pro
https://www.youtube.com/watch?v=P1Z_3ZOCtZ0
Posted: Fri Jun 28, 2019 6:25 pm
The muffler is now re-cored to match the KX500 ID..
It was a real job trying to find someone to weld Titanium for me.
My new friend Rob Jeffers did a great job.
He is now working on the pie pieces to go from the inlet of the muffler to the outlet of the expansion chamber...
Can't wait to hear it when it's done...
- 20190627_194025_resized.jpg (442.7 KiB) Viewed 7245 times
- 20190627_194008_resized.jpg (254.92 KiB) Viewed 7245 times
