To see how the engine would sit in the frame I removed the engine mount off the frame.
Now you see it.....
Now you don't.....
I used my Sawsall with a fine metal cutting blade.
Then, after I removed the mount I used a hand grinder and then a orbital sander to smooth it out.
I know it's not necessary as nobody will see it.
Yet for some reason I will feel better
I went ahead and purchased some brand new engine cases for my engine build.
As some of you probably know the left crank shaft bearing journals get really worn and sloppy on K5 engines.
I don't want to do another build any time soon so I might as well do it right to begin with.
This left me with a nice set of blanks for my Mock Up Engine.
I Installed a back up cylinder and head on the old cases and ended up with a good mock up engine.
You will need to drill the rear engine mount holes on the back of the case to make way for the 17mm Pivot bolt.
Do not use a 17mm drill as it is not large enough.
Instead get a 43/64" as it is 0.672" or 17.06 mm.
This is only .01mm or 0.0004" larger than the holes in the frame.
Drilling the cases was a little intimidating but as it turns out it was really fairly easy.
With the hole drilled out I set the engine in the frame to see what all needed to be done next.
Now that I see how it fits, it's time to cut some more on the frame.
