Central Pneumatic Soda Blaster 67625
Post by Sandblaster » Fri Apr 05, 2013 7:42 pm
I need to see what all the hoopla is regarding sold blasting.
So I picked up this cheapie unit at Harbor freight with a extra set of tips and medium soda for about 175.00.
As soon as the humidity goes down a bit I will put in 40 lbs of soda and give it a whirl.
SODA BLASTER.JPG (50.31 KiB) Viewed 8705 times
More to come...
Motorrad
Re: Central Pneumatic Soda Blaster 67625
Post by Motorrad » Sat Apr 06, 2013 5:03 am
Damn money bags.
if you were really rich. you would set it up in a Blast cabinet like mine is.. :roll:
Kx550 Power By
Motorrad
Post by Sandblaster » Sat Apr 06, 2013 5:40 am
Actually that is the plan if I like the results :D
Do you have pics of your set up?
Post by Sandblaster » Sat Apr 06, 2013 9:56 pm
After using it for the first time I can see why people like to use soda.
soda blasting the case 1.JPG (60.04 KiB) Viewed 8692 times
It isn't as destructive as sand blasting can be and does not leave behind the embedded particulates that can dislodge later and ruin your engine :x
It also clean up really easy.
A word of caution.
Do it outside and wear a respirator.
Or better yet, put this setup in a cabinet with ventilation.
That is what I'm going to do with mine.
Also, with this bottle you need a air compressor that can do a minimum of 8.5 SCFM at 90lb.
My compressor isn't up to the task so I'll be upgrading when I have the dough ;)
Post by Sandblaster » Fri Aug 01, 2014 10:30 pm
I finally took an old sand blasting cabinet and mounted the soda bottle on it.
Works great!
It's amazing how many things you find to Soda Blast once you have one set up that you can just walk over and use :-)
SODA BLASTER.JPG (68.47 KiB) Viewed 8180 times
Yeah, it has it's drawbacks... loading the soda into the bottle and I don't have it hooked up to vacuum yet but for the money, it's cool!
Post by Sandblaster » Mon Aug 04, 2014 9:26 pm
Here's a before pic of a carburetor bowl that had been cleaned up using a brush and scraping.
SODA BLASTER before 1.JPG (91.99 KiB) Viewed 8177 times
Here is the same bowl after soda blasting and rinse.
SODA BLASTER after 1.JPG (126.9 KiB) Viewed 8177 times
Some of the damage could not even be seen until we blasted it.
For cleaning carbs, this thing works awesome...
Return to “Product Review”
Users browsing this forum: No registered users and 9 guests
