Sunny Garcia Pro surfer KX Guru Racing, TMR, Racer X Magazine, KX500 build
Re: Sunny Garcia Pro surfer KX Guru Racing KX500 build
Post by Sandblaster » Tue Sep 18, 2018 2:25 am
I'm sure that these will put a smile on Sunny's face..
Post by Sandblaster » Mon Sep 24, 2018 10:29 pm
Something cool showed up this afternoon.
Tom Morgan Ported, polished, head re-cut, decomp, the works.
I have played with a lot of porting myself and for a good all around MX port job this would be hard to beat.
More power everywhere..
You must run good fuel..
This will do the job.
Post by Sandblaster » Mon Oct 01, 2018 11:41 pm
So... who would take a Italian made custom aluminum gas tank made for a KX500 and try to polish it? :lol:
SUNNY GARCIA KX GURU RACING BORMI ALUMIUM KX500 GAS TANK 101.jpg (279.02 KiB) Viewed 9210 times
SUNNY GARCIA KX GURU RACING BORMI ALUMIUM KX500 GAS TANK 102.jpg (350.51 KiB) Viewed 9210 times
SUNNY GARCIA KX GURU RACING BORMI ALUMIUM KX500 GAS TANK 103.jpg (359.16 KiB) Viewed 9210 times
Post by Sandblaster » Tue Oct 02, 2018 10:10 pm
This is a Tom Morgan Racing balanced and assembled KX500 Crank assembly with a Wossner rod.
It is going in Sunny Garcia's build featured in Racer X Magazine.
Something of note... There was no heavy metal used in the balancing of the crank.
Weight was removed but none was added.
For me, that is the best way to balance.
Tom Morgan Racing balanced crank kx500 101.jpg (280.17 KiB) Viewed 9206 times
Tom Morgan Racing balanced crank kx500 102.jpg (301.76 KiB) Viewed 9206 times
Post by Sandblaster » Wed Oct 03, 2018 10:19 pm
And the parts just keep rolling in...
Here we have a Adam Millar custom VForce 2 reed block holder.
They are available from 1/4" to at least 1/2" in thickness.
Can you guess which is Sunny's? :lol:
KX GURU RACING SUNNY GARCIA ADAMMILLAR KX500 V FORCE CUSTOM 101.jpg (467.56 KiB) Viewed 9201 times
Every fastener was removed and red loctite was used to make sure none of the bolts rattle out and destruct Sunny's engine.
Superior quality, superior flow... Feel the power.....
KX GURU RACING SUNNY GARCIA ADAMMILLAR KX500 V FORCE CUSTOM 102.jpg (351.94 KiB) Viewed 9201 times
Post by Sandblaster » Thu Oct 04, 2018 10:34 pm
More work on Sunny's tank
SUNNY GARCIA KX GURU RACING BORMI ALUMIUM KX500 GAS TANK 104.jpg (416.87 KiB) Viewed 9197 times
SUNNY GARCIA KX GURU RACING BORMI ALUMIUM KX500 GAS TANK 105.jpg (372.84 KiB) Viewed 9197 times
Post by Sandblaster » Thu Nov 15, 2018 8:54 pm
Jason hand lapped all mounting surfaces on the cases and performed all of KX Guru Racing case mods to improve lubrication... 8-)
Just need a trip through the vapor blaster and oven and they will be ready for assembly..
KX GURU RACING JT ENGINE WORKS SUNNY GARCIA CRANKCASE MODS 101.jpg (406.96 KiB) Viewed 8815 times
KX GURU RACING JT ENGINE WORKS SUNNY GARCIA CRANKCASE MODS 102.jpg (399.8 KiB) Viewed 8815 times
Post by Sandblaster » Sat Nov 17, 2018 10:50 pm
One case has been pre-cleaned...
KX GURU RACING JT ENGINE WORKS SUNNY GARCIA CRANKCASE MODS 103.jpg (454.59 KiB) Viewed 8809 times
KX GURU RACING JT ENGINE WORKS SUNNY GARCIA CRANKCASE MODS 104.jpg (201.99 KiB) Viewed 8809 times
Post by Sandblaster » Mon Nov 19, 2018 11:42 pm
I've got the other case vapor blasted but again, there will be more work to be done before it's ready for assembly..
You can see that we put a lot of effort into cleaning things up.. :o
KX GURU RACING JT ENGINE WORKS SUNNY GARCIA CRANKCASE MODS 105.jpg (442.98 KiB) Viewed 8797 times
Post by Sandblaster » Wed Dec 12, 2018 2:03 am
Hammerhead came though with a nice shift lever.
I have used Hammerhead products for years and I can tell you from experience that they are top quality.
Users browsing this forum: No registered users and 9 guests
