KX500 foot pegs. What else will work?
A look at your chassis
Zerofear66
Post by Zerofear66 »
Does anyone know what other bikes will cross over?
Im looking for some wide, over sized pegs for 2003 KX500
Zerofear66
Re: KX500 foot pegs
Just ordered these little beauties.
https://www.ebay.com/itm/SUNLINE-Stainl ... 2749.l2649
Re: KX500 foot pegs. What else will work?
I just got a update from the member that started this thread and the pegs he bought from eBay did not fit.
If you don't mind a little grinder here and there, you can use the following pegs
Torque one sent us some killer foot pegs for a YZ450F for Sean Colliers bike "The Beast".
But they won't fit on a KX500.
So, the first thing we gotta do is remove these tubes..
Calling Mr. Sawsall..
But they still won't fit...
So into the vice for a little hand work..
Grind, grind, grind, file, file, file...
Check it often... Unless you have a mill, then just mill it to the correct thickness..
But, your still not done...
You will need to remove some more material as shown in yellow.
Go slow and do a ton of test fitting..
Then a little clean up on the buffer..
On my Supermoto I used some pegs from a 1999 - 2015 YAMAHA YZ85/YZ125/YZ250/YZ250F/YZ400F/YZ426/YZ450F
Sorry, I don't have a bunch of pics to show how I did it...
But all I used was a hand grinder and a file...
Here is some dimensions on the Yamaha Torc 1 pegs that we modded for Sean's bike.
Here is the IMS KX500 Core Enduro pegs
IMS KX500 ENDURO 101.jpg (163.82 KiB) Viewed 14797 times
IMS KX500 ENDURO 102.jpg (151.93 KiB) Viewed 14797 times
Here is the IMS KX500 Core MX pegs
IMS KX500 MX 101.jpg (162.04 KiB) Viewed 14796 times
IMS KX500 MX 102.jpg (154.01 KiB) Viewed 14796 times
Return to “Chassis”
