Page 3 of 5
Re: KX Guru Racing JT Engine Works KX500 Turbo Crank testing
Posted: Tue Oct 23, 2018 12:49 am
OK... Turbo Crank revision 2 is done...
- TURBO5.jpg (231.15 KiB) Viewed 8974 times
Seriously, REV 2 is done.
We just need to put it in a bike and dyno it...
Posted: Wed Jun 03, 2020 4:29 am
and you thought this project was dead... Nope
I have been so busy I just could not get back to it.
But since our two big events cancelled this year it's time to get this puppy rocking!
I have lowered the port timing by removing material from the bottom of the cylinder.
Because the piston now sits above the deck I had to hove the head cut.
I also had to remove material from the pads that the drum valves sit on.
I may have to elongate the holes for the head mounts...
- 20200602_193635_resized.jpg (410.21 KiB) Viewed 8375 times
Posted: Wed Jun 03, 2020 4:30 am
Posted: Wed Jun 03, 2020 4:33 am
as you can see, the cylinder has not been carved upon..
Just lowered..
In the next two weeks I hope to have it finished, broke in, then dyno'd..
- 20200602_205123_resized.jpg (460.08 KiB) Viewed 8373 times
Posted: Fri Jun 05, 2020 7:16 pm
I always try to get something done on my project bikes every day.
But yesterday I was feeling pretty unmotivated.
So I went out to the shop about 8pm and installed the governor cover and called it good
- 20200604_210927.jpg (401.25 KiB) Viewed 8358 times
As you can see, this is not a polished fancy pants build.
Right now I'm in the testing and tuning stage.
Once I dial in this engine, then I will take it apart and apply all the glitter and makeup
Posted: Sat Jun 06, 2020 2:47 am
I was getting ready to put the carb back on when it occurred to me that the jet block o=ring gasket has never been replaced
So, I can't let that stand.
It's good thing I checked it s it was beginning to fall apart.
See that little chunk missing?
It is suppose to be missing..
But, the gasket is starting to fray round it's outside edges.
The bike was still running good but it was just a matter of time...
- 20200605_182433_resized.jpg (258.57 KiB) Viewed 8352 times
Posted: Sat Jun 06, 2020 2:53 am
and those that know me realize that I will never build a KX500 engine without dissembling the air box and cleaning it, then sealing it with some Ultra Black RTV silicone..
- 20200605_153709_resized.jpg (409.74 KiB) Viewed 8351 times
Posted: Sat Jun 06, 2020 2:55 am
Posted: Sat Jun 06, 2020 2:57 am
Posted: Sat Jun 06, 2020 7:22 pm
I'm so close to firing this puppy up but one of my best friends son is having a graduation party and I cant miss it.
So likely it will happen tomorrow...
What will I get for the Graduation present?
Tools.. What else?
- 102675246_3150775701635521_8009663537308733974_o.jpg (238.96 KiB) Viewed 8340 times
